A couple things I do to make the top 2 bolts easier:
-disconnect the 4 boost hoses in the front. -loosen up the two motor mount bolt. -Do not need to touch the heater hoses. Once those are done and the trans brace is removed, the rear of the trans will sit low enough to access the bolts with a 36" extension.
